Blower motor resistor failing
Old Feb 11, 2013 | 01:13 PM
Brock297's Avatar
Brock297
Default Blower motor resistor failing
I have a 2000 Dodge Stratus SE with 176,000 miles. Every year or two the blower motor resistor fails. Easy and cheap enough to replace, but why does it fail? Like I said, after replacing, the new one lasts at least a year, sometimes two before failing again. Thanks for any help.
Brock297
Old Feb 11, 2013 | 09:49 PM
BillS's Avatar
BillS
it could be the fan drawing to much current causing it to fail sooner,also dodge had issued a tsb about a revised resistor that covers 2000's you have to enlarge the opening for the resistor a little. there are no diagrams https://dodgeforum.com/forum/2773175-post4.html
Old Feb 12, 2013 | 12:48 PM
Brock297's Avatar
Brock297
Thanks for the response. Is there a part number for the new resistor?
Brock297
Old Feb 13, 2013 | 07:53 AM
BillS's Avatar
BillS
no don't have the part # if you call dealer with last 10#'s of your vin they should have one or can get one probably around 26 to30 dollars if i remember right
