Electric Locks
Old Mar 3, 2013 | 12:37 PM
mitch611's Avatar
mitch611
Default Electric Locks
Just bought a Stratus for my 16 year old and the electric locks won't work correctly. The fob and the door switch will unlock the doors but won't lock the doors. When using the fob, the horn chirps as if locking but won't lock. All of the other fob functions as supposed to. I am thinking a wire is loose somewhere but not sure where to look. Any help out there?
Old Mar 3, 2013 | 01:23 PM
BillS's Avatar
BillS
what year and model(sedan or coupe)?,have you checked fuses, you might try unhooking battery for 10 minutes see if that does anything
Old Mar 3, 2013 | 02:54 PM
mitch611's Avatar
mitch611
I will try that. It is a 2002 Dodge Status Sedan with the 2.7. I read there were separate modules for locking and unlocking but I don't have a clue where it would be to check. Thanks for the reply.
Old Mar 8, 2013 | 01:37 PM
mitch611's Avatar
mitch611
Okay, tried the battery and checked all fuses with same results. Is there a module somewhere that controls the remote and door switch? Strange that it will unlock and sound horn but will not lock.
Old Apr 9, 2013 | 02:40 PM
classicfan1's Avatar
classicfan1
Well, my '98 Stratus had this same problem on the driver's door. The gearbox was worn out. I replaced the whole assembly for $30 at a junkyard. My guess is the cam or whatever was inside just wore out over time. I mean, the car at 265K miles when I replaced it and it was original.
