rt stratus turns over but no start
Old Mar 7, 2013 | 02:36 PM
kenyanr1's Avatar
kenyanr1
Default rt stratus turns over but no start
Guys, i can feel my fuel pump running when i try and start the car. It sounds like it wants to fire, but it wont. Im lost [once again]. I read that i may need a new cam sensor. My car threw a random cylinder misfire code before i changed the plugs. Now it reads that i pass and dont have any codes. Any help much appreciated
Old Mar 7, 2013 | 03:36 PM
kenyanr1's Avatar
kenyanr1
sorry, car is a 2002 rt stratus
Old Mar 7, 2013 | 05:43 PM
D Ryan's Avatar
D Ryan
You need to check for spark! You need to get car running again to get most codes! Take a test light connected to GROUND - , see if a spark happens when cranking.
Here is a video of it being done!
Old Mar 9, 2013 | 05:39 PM
kenyanr1's Avatar
kenyanr1
Thanks for that D ryan. I checked and there was no spark. I also sprayed starting fluid in the throttle and still no start. Any suggestions ? Car still turns over but no start. Any help is much appreciated guys !
Old Mar 9, 2013 | 07:07 PM
D Ryan's Avatar
D Ryan
There's your problem!!!!!!!!!!!!!!!!
First check the fuse's (key must be ON)
Do a visual inspection of the wiring! CRANK and CAM sensors at where they plug in! Also check to see if coil is plugged in.
Find the wiring diagram for your eng. What is it?
This car was running!!!
Old Mar 12, 2013 | 08:44 PM
D Ryan's Avatar
D Ryan
Any progress?
Old Mar 12, 2013 | 09:01 PM
cumminspower_96's Avatar
cumminspower_96
on my 96 ram with the 318 5.2 i have no spark at all. i have replaced all the plugs, wires, coil, and now the distributor pick up coil and still nothin anyone one have any ideas?
Old Mar 12, 2013 | 09:50 PM
D Ryan's Avatar
D Ryan
You need to start your own thred, it gets to confusing, you also should do the thred in the right fourm!
Old Mar 12, 2013 | 11:46 PM
D Ryan's Avatar
D Ryan
food for thought!
Old Mar 26, 2013 | 11:33 AM
kenyanr1's Avatar
kenyanr1
Thanks D-ryan! Sorry, i didnt see you had re-responded. For some reason i am still not getting spark. I changed the cap and rotor and still no spark. Just today i purchased a distributer and crank position sensor. Hope this works...
