Fuel pump testing/pressure/wiring
Old Mar 19, 2013 | 07:02 PM
D Ryan's Avatar
D Ryan
Default Fuel pump testing/pressure/wiring
You will have to go to there site and jump through there hoops to see the information but worth will! You wiill have to input your make, model, eng, ect!
shows connecting a pressure tester without a schrader valve, ground wire tips, different kinds of fuel line connectors! Good stuff if you dont know! Its all in video's!!!
http://www.fuelpumpu.com/vehicle-search.aspx#
Old May 31, 2013 | 07:01 AM
BradLittlefield's Avatar
BradLittlefield
Just bumping this up, answered a lot of dumb questions I had about fittings and connectors. (mostly, can you use a diff type of male connector for the same female fitting) - The answer, is yes. He uses like 15 different connectors on the same fuel pump female fitting.
