1997 stratus 2.5 engine CEL problem p0112 and p1496
Old Mar 30, 2013 | 05:20 PM
D Ryan's Avatar
D Ryan
Originally Posted by csmith177
I removed the fog light and a wire on the fog light is the same color as the sensor grounds. Fog lights have not worked since I got the car last month. I wonder if it could be somewhere in a ground for those
Wouldent think so , the fogs are grounded to the frame somewhere! (pull the fuse) Those other sensor are grounded inside the computer , except heated 02.
Old Apr 3, 2013 | 02:21 PM
csmith177's Avatar
csmith177
Just an update. I still havnt been able to locate a short anywhere. I just ordered a PCM off ebay. Im thinkin if there is a shirt it must be internal. Keeping fingers crossed until it arrives in the mail
Old Apr 4, 2013 | 10:45 AM
D Ryan's Avatar
D Ryan
Sence you have a computer coming , disconect the plug on the computer and OHM the wire leading to the IAT!(BLK/LT BLUE)!
When your done! OHM that wire again with MAP sensor disconnected!
If you want to check out that new IAT sensor you could also OHM it! Use a hair dryer to watch for change!
Old Apr 5, 2013 | 11:15 AM
D Ryan's Avatar
D Ryan
Paul Danner just made another video concerning low voltage, you might like this.
Old Apr 5, 2013 | 02:37 PM
csmith177's Avatar
csmith177
I just popped in the new computer and started right up. No cjeck engine light and no codes found :-D
Old Apr 5, 2013 | 03:49 PM
D Ryan's Avatar
D Ryan
Well done! Enjoy your fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 15, 2020 | 08:49 PM
Rocky Aguillon's Avatar
Rocky Aguillon
How long did the repair last? Was this the problem? Am having the same issue
Old Dec 15, 2020 | 09:16 PM
csmith177's Avatar
csmith177
Oh wow this post was from 7 years ago. I forgot how to log in here but finally figured it out. Yes, if I remember correctly the pcm off eBay did fix the problem. I eventually sold the car but it was still working when I sold it. Just make sure if you get one on eBay that it is preprogrammed to your vin number. That's the cheapest place I found it back then... Funny thing I just looked back saw where the other person posted a video. And scanner danner the one teaching in the video is somebody I still follow on youtube today.
