A/C Clutch is not engaging
Old Mar 30, 2013 | 05:47 PM
jdmontel08's Avatar
jdmontel08
Default A/C Clutch is not engaging
So my 04 Stratus's ac clutch is not engaging. The first thing i did was replace the clutch relay(fuse). Unfortunately it did not fix the problem. I checked all off the wires connecting to the compressor and all seems ok. The day before I noticed the problem, the ac worked just fine. Nothing out of the ordinary. What could possibly be the problem?
Old Mar 30, 2013 | 07:15 PM
BillS's Avatar
BillS
what do you have a sedan or coupe ?if its a sedan try this first if it just stopped suddenly . remove fuse #5(there might be a cover over it that you need to take off)(or you can unhook battery for 10 minutes) from the fuse box thats inside car for at least 10 minutes, reinstall fuse start car let idle for at least 5 minutes. check to see if a/c works then
