Window motor question
Old Apr 4, 2013 | 03:30 PM
Lyonsju22's Avatar
Lyonsju22
Default Window motor question
Hi I have a 98 stratus 4 door. My front passanger side window motor went out I think. Would the rear passanger window motor be the same as the front passenger? Also the reason I think it could be the motor because when you try to use the window it moves just a little then quits. Before this it would start getting slower and slower then it went to this where it wont go anywhere.
Old Apr 9, 2013 | 02:23 PM
classicfan1's Avatar
classicfan1
I would also check the window regulator and the guides. If the motor realy is bad, you can get one out of a junkyard for about $20 or so. I always bring a test battery with me to test electrical parts whenever possible. I use the 6V battery from my dad's remote control airplanes. It's not much, but it will show the part(s) work before I pull them off.
Old Apr 9, 2013 | 02:25 PM
classicfan1
Oh and finding 1st gen Stratus' in junkyards here has proven to be difficult, especially '98 models. The only '98 in the local yards is stripped bare, down to the bare body with the dash, rear doors, and rear window remaining. I know of two "honey holes" so hopefully you will have some luck finding your parts.
