Engine swap help
Old May 4, 2013 | 12:09 PM
viktorcreed's Avatar
viktorcreed
Default Engine swap help
I was wondering if I could swap my engine from an 04 stratus sxt with 01 rt?
Old May 4, 2013 | 12:26 PM
BillS's Avatar
BillS
not sure maybe someone can answer there need more info it won't work if one is a sedan(dodge engine) and one is a coupe(mitsubishi engine)
Old May 4, 2013 | 12:38 PM
viktorcreed
Both are coupes
Old May 5, 2013 | 03:07 PM
ratsttam's Avatar
ratsttam
Originally Posted by viktorcreed
Both are coupes
You should be able to physically make it fit. Verify the position of the motor and transmission mounts, I believe the transmissions are the same between the engines (41te). Possibility that you may need to swap the ECU's.
Old May 10, 2013 | 01:46 PM
JTR's Avatar
JTR
What kind of engines are they?? 4 cyl's or V6's??, manual or auto trans??
Old May 11, 2013 | 10:46 AM
viktorcreed
My 04 stratus is 4cyl, and the 01rt is 6cyl. Both are automatic.
Old May 15, 2013 | 12:46 PM
JTR's Avatar
JTR
According to the mitsu site I researched before my 3.5 swap, the trans will not interchange between the 4 cyl and 6 cyl. Apparently they have different bellhousing bolt patterns. check out this site http://www.club3g.com/forum/ and search there for more info.
