Wet floor
Old Sep 12, 2013 | 11:18 AM
NH R/T's Avatar
NH R/T
Default Wet floor
My front and rear carpets on drivers side are constantly soaked WTF is causing this?
Old Sep 12, 2013 | 11:31 AM
BillS's Avatar
BillS
what kind of car year model, does it get wet when it rains do you have sunroof/ moon roof , or when you use air conditioner ,how's the door seals look
Old Sep 14, 2013 | 11:00 AM
NH R/T's Avatar
NH R/T
sorry was in a hurry......... 2001 stratus r/t with sunroof(does not leak).Not from a/c or heater core. i heard something about drains for sunroof?bbut doesnt really make sense to me..i will check door seals. we had torrential rain 2 days ago 6"+ and carpets stayed dry ( car parked)
Old Sep 14, 2013 | 03:45 PM
BillS's Avatar
BillS
not to familiar with coupe think there's drains in the drivers front door pillar and drain holes underneath the fender behind the tire that can get clogged ,mentioned a/c because sedans had a problem with drain clogging up
Old Sep 15, 2013 | 06:34 PM
NH R/T's Avatar
NH R/T
I didnt realize the a/c had a drain how can i find it
Old Sep 15, 2013 | 08:13 PM
BillS's Avatar
BillS
not sure on exact location on coupe, you have to raise and support car on sedans its located underneath car behind engine on firewall , when I flushed mine used a broken piece of garden hose with a 3/8ths inch outer diameter think it was 2 foot long piece of gray plastic tubing from home depot plumbing dept. taped to end of cut hose . insert tubing into drain with water running as far as it will go in for a few seconds and remove
Old Sep 16, 2013 | 04:48 PM
tomf2011's Avatar
tomf2011
I have a 2002 Stratus R/T that had the same problem. It soaked both the front RH/LH side of the car. It also soak the amp under the seat which is NOW shot. Check your amp its under the passenger seat.
Anyway BillS is right, there are drains in the RH/LH front door pillars. That is your problem! They are real small and get clogged. Follow the groove on the roof above the doors down to the front windshield rigth by the pillars. There is a small hole there with a hose the goes down the inside of the pillar and drains under the car at the back of the front fenders.
I ran a small wire down the line and flushed it out with HOT water. The car is dry now but I don't have a stereo any more.
Hope this helps!
Old Sep 16, 2013 | 09:05 PM
NH R/T's Avatar
NH R/T
thank you tom i will look there
