Transmission Slips
Old Nov 2, 2013 | 04:07 PM
dgp's Avatar
dgp
Default Transmission Slips
The transmission is slipping occasionally due to a slow unidentified leak. I'm using the thick anti-slip fluid and that helps.
I'm about to go under the car and look for the problem, however I'm not sure where to start. I have the Chiltons manual, but can't find a blow-out showing where the various gaskets and seals can be found. All the images are close-up and I need the large overview of where to look.
Any leaks to a diagram or illustration would be appreciated. I'm thinking of getting the car up on the ramps, then power washing the undercarriage so I can look for fresh fluid.
When the transmission fluid is filled, there is absolutely no slipping. Therefore, I believe a leak is the only problem. I'd like to fix it myself.
dgp
