2000 Stratus, broken water pump
Old Dec 21, 2013 | 06:27 PM
14269's Avatar
14269
Default 2000 Stratus, broken water pump
My 2000 Stratus 2.0 have enden up with a broken waterpump. Will that couse with bent valves and a broken engine or will the engine be ok, when the pump is replaced?
Old Dec 22, 2013 | 08:46 AM
BillS's Avatar
BillS
think that is an interference engine , if it broke the timing belt or it jumped timing very possible, depends on how it broke
Old Dec 22, 2013 | 07:11 PM
armaniEfiftyfive's Avatar
armaniEfiftyfive
No your ok.. as long as the car didn't overheat in addition when the timing belt goes that's when you have a higher chance over causing havac to your valves.
I would recommend getting your timing belt replaced if your going to replace your water pump. thermostat ,water pump and timing belt should always go hand in hand. cheaper and I would imagine your hoovering over 100k+
GL
Armani
Old Dec 25, 2013 | 09:16 PM
14269's Avatar
14269
New timing belt and waterpump are ordered....
Old Jan 6, 2014 | 07:27 PM
14269's Avatar
14269
New waterpump and timing belt is replaced. Everything works ok, so far. The pressure at each cylinder is ok (around 9). The testdrive looks also ok. :-)
Old Jan 7, 2014 | 08:26 AM
armaniEfiftyfive
That's great! How many miles on the Dodge? Did you do the work yourself ? It's really tough to remove and replace timing belt not a lot space to work with
Old Jan 8, 2014 | 09:56 AM
14269's Avatar
14269
About 180 k kilometers. Yes, I did it by myself. It is not so much space, but enough! .....but you had to know what you are doing... and dont forget to replace the waterpump!
