Dodge Stratus timing belt broke ; easy way to check for bent valves?
Old Mar 16, 2014 | 09:47 AM
dougstractorworksinc's Avatar
Default Dodge Stratus timing belt broke ; easy way to check for bent valves?
I have a 99 Stratus 2.0 , 4 cyl. 5 speed that the timing belt tensioner bearing went out ; is there an easy way to check for bent valves ? The car has 435,000 miles and I don't want to invest a lot of repair time if the valves are bent
Old Mar 16, 2014 | 10:42 AM
BillS's Avatar
BillS
no easy way that i know of, only two things i know would be pull the head and check, or put the belt on and see if and how it runs
Old Mar 16, 2014 | 12:31 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Put the new timing belt on. You don't have to put it entirely together, just the belt. Make sure everything is clear of the belt path and run a compression test.
