2001 Dodge stratus R/T
Take off the front trim above the center console where your radio and in car thermostat is at. Pull out your radio next, (I wouldn't unhook it, unless you know how to put it back in.) Balance it up by the out of car thermostat, or where it says stratus (depending on trim). Then look at the top of the heat controls and make sure that the pulley systems for the fans and directional are still conected and that all of the wires are tight. (There are two screws holding in that trim piece on the bottom near cig outlet, after that should pop right off.)
