multiple misfire, rough idle, timing jumping
Old May 26, 2014 | 02:49 PM
hackmanfool's Avatar
hackmanfool
Default multiple misfire, rough idle, timing jumping
Please help. 2003 RT multiple misfire code. Has new cap, rotor, plugs, wires, changed out distributor. Did compression test, injectors good. New timing belt and pulleys, water pump. Idling bad, tough to start. Had jumped timing. Reset not working. What should I do?
Old May 27, 2014 | 06:39 AM
pearl01stratcpe's Avatar
pearl01stratcpe
Timing could be off a tooth, or you have a plug wire or two switched.
