2005 2.4L timing belt
My 2005 Stratus has 108k miles and I read codes P0016 & P0339. I replaced the cam sensor at ~80k so I 'm thinking this may be a warning the timing belt needs replaced. I watched a video online about changing the timing belt and they mentioned a special vibration damper puller from Dodge. I have a puller I've used for dampers on other cars and was wondering if anyone knows if this special one is necessary? Is there any info on the forum that shows/explains the procedure to change the belt. All help greatly appreciated. thanks, Gary
