Possible ground wire/BCM issue
Old Jul 5, 2015 | 06:21 PM
V_pecak's Avatar
V_pecak
Default Possible ground wire/BCM issue
2000 Dodge Stratus
When it is hot outside, gauges, windshield wipers, locks, and AC do not work.
Sometimes they will turn on after driving for a while, sometimes they never turn on.
I've had people suggest ground wire or the BCM to be the issue. Do you think that is the issue? Is that something I can fix by myself?
Thank you for your help,
Victoria
Old Jul 18, 2015 | 10:43 AM
atcfreak250's Avatar
atcfreak250
New Member
im having the same issues, gauges are dead as are the wipers and defroster.car runs fine.just gauges dies when hot its hot out. i also get a NO BUSS in the trip meter.
Old Sep 4, 2017 | 03:50 PM
ratt's Avatar
ratt
Talking
Originally Posted by V_pecak
2000 Dodge Stratus
Victoria
The problem is simple brush the BCM with wire brush contacts no dielectric grease just a brush the contacts with a stainless steel brush
Old Jun 13, 2020 | 09:20 PM
rwaltemate's Avatar
rwaltemate
2008 Ram 2500 4 door HD 5.7L SLT
Windshield wiper linkage for the passenger side... the plastic cup faces upwards and grit gets into it and wares the hole large enough to fall off. Now on my 3rd one (can't just get the part either) on my 2008.
ABS Control Module is a male plug facing up with a plastic extrusion around it that holds water. The prongs on the ABS Module are not copper and rust off. LOL. I think this is 99% of the issues with speedometers not working and people with ABS & Brake light illuminated on the dash.
I do drive my truck on the beach (Pacific Ocean) in SW Washington so it gets a lot of sand and salt air, so some of this may just be the environment I am in that I have listed below
Rusted though one oil pan
Rusted though both lower control arms on the front axle
Rusted though the emergency breaks guts inside the read rottor
Just noticed transmission fluid on the ground so likely another item killed via salt water. hahaha.
and for whatever reason I get a codes for a bad air intake temp sensor. I replaced it once and then just gave up on it. I could clear the code and it would reset once in a while.
Overall I really "use" my truck and it has held up good, but the more electronic stuff they add, the worse it is.
Old Mar 14, 2023 | 04:25 PM
Dmoss's Avatar
Dmoss
There are two terminal on the Starter which one do I use or does it matter
Old Mar 14, 2023 | 04:26 PM
Dmoss's Avatar
Dmoss
Default Starter terminal
Old Jun 30, 2023 | 09:32 PM
FabricGATOR's Avatar
FabricGATOR
Do you have a picture to share?
Have you0 already repaired or found your answer? Please update your findings...
