timing trouble
i just got a 2000 stratus 2.5 an needed a water pump so i replaced it the timing belt was good so i marked it and reused it i did everything according to book didnt use special tool for pulley but torqued it and tensior pim slid in an out after i turned a couple revolutions and marks seemed to still be good with the crank mark put it back together and w0ont start the starter makes a little noise like the bendex is going out but it turns over fine but wont piclup i had to charge the battery and wondered if that might effect it starting it ran fine before i put the pump in just leaked should start fine again i would think any i deas? thanks
