pink or green antifreeze ?
Old Aug 27, 2015 | 09:23 PM
mylastcar's Avatar
mylastcar
Default pink or green antifreeze ?
friend bought 01 Stratus R/T Coupe with about 70,000 miles on it. will assume the the belt was changed on the v-6.
he says the anti-freeze in it was green,i thought it should be pink.
so from 03 to present .... with green anti-freeze , what are the affects ?
Old Aug 28, 2015 | 01:32 PM
pearl01stratcpe's Avatar
pearl01stratcpe
Original color is green. I assume if the system gets flushed you can put whatever you want in. I dont believe it is advised to mix different colors though.
Old Aug 29, 2015 | 08:26 AM
mylastcar's Avatar
mylastcar
thanks for the quick reply
whats your history with your Dodge Stratus ?
how far did you go into it to rebuild it ?
Old Aug 29, 2015 | 10:11 AM
pearl01stratcpe
Ive owned my car for 9 years. Ive helped members on another forum but most had the V6, I own the I4. I havent had to do much to mine maintenance wise except for drop the transmission and put in new bearings. I helped a guy with a similar generation Eclipse Pull his motor due to a bad bearing and install a newer motor once. We did a full timing belt job on it before it went in.
Old Aug 30, 2015 | 12:40 PM
mylastcar's Avatar
mylastcar
thanks, you know these cars well
