Can't find Evap Purge Solenoid 1997 Stratus 2.4L
Old Sep 13, 2015 | 04:46 PM
jlindseyjr's Avatar
jlindseyjr
Default Can't find Evap Purge Solenoid 1997 Stratus 2.4L
I'm having an issue where when I gas up the pump keeps stopping. All the research I've done says my evap canister might not be purging.
I wanted to check the purge valve solenoid but I can't find it. Haynes manual says it's supposed to be on the driver side shock tower. It ain't there.
Then I thought, what if the engine had been replaced with a 98. It should be right next to the windshield washer filler. Nope.
I'm at a loss. Anyone know where else it could be?
Old Sep 15, 2015 | 02:53 AM
Douggro's Avatar
Douggro
The purge solenoid should be near the coolant reservoir; the leak detection pump, if equipped, is adjacent to the fuel tank and evap canister. There is a check valve in the filler neck that may be causing your problem..
Old Sep 16, 2015 | 11:25 AM
jlindseyjr's Avatar
jlindseyjr
Thanks for the info. Valve is ok. Now to pull the filler neck.
