05 dodge stratus rought start an cuts out at 2300rpm
Old Oct 21, 2015 | 05:50 PM
Stacy Lynn's Avatar
Stacy Lynn
Question 05 dodge stratus rought start an cuts out at 2300rpm
the ca ris rough to start an cuts out at 2300rpm, it showed bad camshaft sensor an crank shaft sensor, had them changed an didnt help, it has 167,000 miles, it runs smooth an idles smooth. any ideas
Old Oct 22, 2015 | 08:03 AM
Have you tuned it up?
Old Jun 27, 2016 | 05:43 PM
vfiffie's Avatar
vfiffie
Did anyone every figure this one out? I have a 2006 stratus with the 4 cylinder. It gave a multiple misfire error code. When accelerating the car wants to kill and has no power at all and the max rpm is around 4500. I disconnected the MAP sensor and the car idled fine and ran with power. When I put in a new MAP sensor the car ran bad again. As long as the MAP sensor is disconnected the car runs great but the engine light is on. The plugs are new, wire new, coil pack new, o2 sensor new.
