need confirm that im looking in the right place
Old Dec 7, 2015 | 05:41 PM
cleverace's Avatar
cleverace
Default need confirm that im looking in the right place
Hi i have a 2004 dodge stratus 2 door sxt 2.4 engine, great car i havent had to work on it much.
Recently the check engine light came on so i ended up buying a actron cp9125 scanner because i borrowed a friends to scan the car at first and it work well.
got 2 codes po335 crankshaft position sensor
and po340 camshaft position sensor
Replaced the camshaft sensor that was easy but while search for the loction of the crankshaft sensor i found several locations where mine was not located:
above the oil plug =no
in between the two transmission bolts on firewall side= no
under the starter= no
near or below the alternater on fire wall side=no
so it is not visable anywhere on this engine
I am assuming the crank sensor is located behind lower timing cover. Can any confirm this for me?
I have always been a procedure wrench turner so any links for a step x step to r&r would be great also thanks
Old Dec 7, 2015 | 07:24 PM
pearl01stratcpe's Avatar
pearl01stratcpe
Page 55. http://tearstone.com/eclipsefsm/GR00001600-16.pdf
It is under the lower timing cover.
Old Dec 7, 2015 | 08:25 PM
cleverace's Avatar
cleverace
thank you
