2004 r/t coupe RADIO HELP
Old Aug 10, 2016 | 02:58 AM
Manny Mora's Avatar
Manny Mora
Exclamation 2004 r/t coupe RADIO HELP
- one small white clip with 2 wires
DARK GREEN w/ORANGE STRIPE
DARK GREEN w/BLACK STRIP
- one 7 pin black clip with 7 wires,
WHITE w/BLACK STRIPE
YLLW w/ BLUESTRIPE
YLLW w/ RED STRIPE
WHITE w/ BLUE STRIPE
WHITE w/RED STRIPE
GREY w/BLUE STRIP
GREY w/RED STRIPE
- one great clip with 7 pin slots, 6 actual wires
RED w/WHITE stripe
WHITE w/ BLACK STRIPE
BLACK w/ YLLW STRIPE
DARK GREEN w/ WHITE STRIPE
BLACK w/ RED STRIPE
BLACK w/ BLUE STRIPE
HELPPPP
Old Aug 10, 2016 | 08:04 AM
What exactly do you need help with?
Old Aug 10, 2016 | 11:22 AM
Manny Mora's Avatar
Manny Mora
i have a new headunit that i want to install, but the wiring for the clips behind the STOCK headunit do not match any discription i have found, there are NO plain colored wires, the list of what i see is listed in my post, i have had a hell of a time finding anything on the wiring color code or correct diagram that fits my 2004 dodge stratus R/T coupe with infininity system. there are area a door panel speaker in each door, tweeters as well, a center speaker and 2 up behind the backset headrests ( that i can see) i just want to know what goes to where.
Old Aug 10, 2016 | 01:57 PM
If you get the adapters required to integrate with the infinity amp?
Old Aug 11, 2016 | 12:28 AM
Douggro's Avatar
Douggro
crutchfield.com has harness adapters for fitting aftermarket head units. If that's what you're doing, that's where to look. The Infinity systems usually have an amp unit in the speakers and a relay that's tripped by a signal from the head unit to power the amps.
Old Aug 12, 2016 | 07:57 AM
The infinity system in the stratus coupe is most likely just like the one in my eclipse. The amp is under the passenger seat.
