2.4 Timing Tensioner Q'
Old Nov 12, 2005 | 08:51 PM
sinistertrucker's Avatar
sinistertrucker
Default 2.4 Timing Tensioner Q'
How do I loosen/adjust it?? Which pulley is it?? (kids destroyed the pages on my manual)
Thanks.
Old Nov 13, 2005 | 01:47 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: 2.4 Timing Tensioner Q'
do you have a belt routing chart somewhere under the hood? ive not dealt with a 2.4, but i know that the 420a (2.0 neon motor) used a pin tensioner, and two idler pullies.
Old Nov 14, 2005 | 10:36 PM
brandoncrone's Avatar
brandoncrone
Depends on what year it is. If it is a 95 it has a small hydraulic ram down at the bottom next to the crank pulley, if it is newer, its the pulley just above and to the rear of the crank pulley. Loosen the 10mm bolt in the center and use a 7 or 8mm allen wrench to rotate the pulley counterclockwise to loosen.
Old Nov 14, 2005 | 10:37 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
ok thanks brandon..i wasnt sure
