Accident!!!!!!!!!!
Old Oct 20, 2016 | 07:58 PM
redsl's Avatar
redsl
Default Accident!!!!!!!!!!
Hey guys just rear ended a pickup truck. Most of damage is on top and left fender. But here's the thing, the car is in park but you can move it around likes its in neutral. the trans did not get hit can it be the trans went bad from the hit. It was working great up until the accident. Also the plastic trim that goes around the sparkplugs was broken what is that part called and can I buy a new one anywhere. The air box was broken too gong to try junk yard but don't know how it comes out. Well any help would be appreciated with any of the problems listed thanks. Its a 2006 Stratus STX
Old Oct 29, 2016 | 03:40 PM
NH R/T's Avatar
NH R/T
bent frame structure? does trany still work at all maybe broke linkage
Old Nov 14, 2016 | 07:32 AM
smokesxt's Avatar
smokesxt
It's possible that the hit broke the diff pin. Or on the lighter side, could have just broke the linkage.
Old Nov 14, 2016 | 07:52 AM
Hidden damage. Need to get in there and inspect everything.
Old Nov 14, 2016 | 07:29 PM
Sonocativo's Avatar
Sonocativo
FWD, the linkage (if I'm correct) connects to an arm that is on a cover that actually shifts inside the housing , I had a Daytona and the little ball-stud end jumped out of the socket. Simple fix if it is anywhere the same . Can be done from impact or even jambing the gear shift (assuming this is a manual trans)
