No crank No start
Old Mar 14, 2017 | 01:23 PM
theotherguy's Avatar
theotherguy
Default No crank No start
Hello,
I am having a no crank, no start issue with my 2003 Dodge Stratus, 4 dr, 4cly.
Here is what I know and what I have done so far:
- Battery is at a full charge and I check it before attempting to start each time I replace something.
- I took out the starter and had an auto parts store test the starter and they said it was perfect (it has about 10,000 miles on it)
- I tested the red battery cable going to the starter and it has full power.
- I tested the trigger cable (not sure if that's what it's called), the cable that should be powered when the key is in the crank position and it is NOT getting any power when the key is in the crank position.
- I replaced the ignition switch, no change
- I replaced the actuator pin going into the ignition switch, no change
- The starter is grounded
What else should I test or replace? What am I missing here?
Thanks for any help or advice that anyone can give on this.
Old Feb 6, 2024 | 08:39 PM
Tharless22's Avatar
Tharless22
Did you ever figure out your issue? I'm having the same problem
