Crankshaft Position Sensor
Old Mar 20, 2017 | 10:09 AM
turtlejuggalo's Avatar
turtlejuggalo
Default Crankshaft Position Sensor
Hey all again.
I have a 2004 RT coupe 3.0 v6 and it is going to be the death of me.
I had to have the waterpump and timing belt replaced recently. After that it was running just fine for a couple weeks, then a strange noise(sounded like I was driving a go cart is best way for me to put it) started from under the rear valve cover. Then I lost so acceleration and the check engine light came on. I had the codes read and it was spitting out camshaft sensor and crankshaft sensor codes for misfires. So I took the car home and when I got home the car cut off and now it wont start at all. Well since I had the whole weekend free, I changed the sparkplugs, wires, cap, and both valve covers. (it needed to be done). Also discovered I had a bad oring on a fuel injector and fixed that. Well the car still wont start, So Im guessing the crankshaft sensor is bad since I dont have a camshaft sensor that I know of.
So to get to my questions....
1. where is the crankshaft sensor? NVM, I found out where it was...
2. Anything else it might be instead of the sensor?
Thanks in advance
Stephen
Old Mar 25, 2017 | 09:48 PM
Savanna Brokamp's Avatar
Savanna Brokamp
Default Yeah
Yeah once you replace it you have to turn it and eighth of an inch
