A/C blinking
Old Apr 12, 2017 | 09:13 AM
NH R/T's Avatar
NH R/T
Default A/C blinking
'01 r/t coupe 3ltr...................when i turn on my a/c after a couple minutes the light on switch starts blinking and a/c stops working.Shut car off and restart , works for minute and does the same thing...help
Old Apr 12, 2017 | 09:15 AM
turtlejuggalo's Avatar
turtlejuggalo
I have an 04 RT and have this same issue. Gonna follow to see if someone has the answer.
Old Apr 12, 2017 | 09:32 AM
Check the belt. It will flash if the belt is slipping. There could be any number of things that causes the A/C light to flash though: low refrigerant, bad compressor, clogged system components, etc.
Basically, you won't really know what's wrong until you take it to a mechanic that you can trust.
