Dodge Stratus Stealth Motor
Old Jul 7, 2017 | 03:04 AM
Jon McNew's Avatar
Jon McNew
Default Dodge Stratus Stealth Motor
SO... i have had this idea that the dodge stealth motor that had the DOHC and twin turbo could possibly fit inside the dodge stratus... since it is the same platform... but when i looked up some stuff i couldn't really find anything that said there was a way to do it. Most places said you can only really put one turbo on the stratus. But what about swapping the heads... will atleast that work?
Old Jul 7, 2017 | 08:20 AM
No, I don't think so. The stratus is built on a different platform (ST-22; Sebring, Stratus, Eclipse, 2000-2005) than the stealth. The stealth platform, (Z11A, Z15AM, Z15A, Z16A, 1991-1996) is equal to the 3000GT. That being said, with enough time, money, tools and fabrication skills, anything can be done.
Old Jul 12, 2017 | 08:15 PM
SST97's Avatar
SST97
I'm starting to look in to this. I'm wondering what all would have to be done in order to put the complete turbo system into the stratus, if I bought a junkyard stealth or 3000. Of I have to fab some stuff, including modifying the hood, then so be it.
Old Jul 14, 2017 | 02:34 PM
smokesxt's Avatar
smokesxt
The width of the DOHC engine becomes a problem very quickly, especially with a turbo on each bank.
It is much wider than the SOHC which powers your Stratus.
Width is the reason I backed out on putting a 6G75 Mivec in my van. It required too much cutting of the chassis to make it fit.
Old Jul 15, 2017 | 02:18 PM
Jon McNew's Avatar
Jon McNew
Default Well then
But the stealth motor is built using the same block right? so the heads will possibly at least swap onto the motor with a little fab work on the firewalls maybe?
Old Jul 17, 2017 | 07:10 AM
smokesxt's Avatar
smokesxt
Same block mostly.
The timing setup on the DOHC is different from the SOHC, so the heads can not be interchanged.
What is the reason behind wanting to do this swap?
If it's power, a 6G74 or 6G75 swap is a much more viable option, or you can boost your SOHC.
