1995 Stratus computer replacement?
Have been told our 1995 Dodge Stratus needs a new computer. 6 cylinder engine. Some symptoms are check engine light is usually on and car dies out occasionally. Mechanic says cannot check codes since computer is bad. Says computer replacement would be about $1000. I did some internet searches, I assume the computer the mechanic is talking about is an ECM? From what I've seen 1995 Stratus ECMs do not have to be flashed? Figure you are talking to a complete novice when it comes to car repair, I can change oil, plugs, filters and basic parts, that's about it. So where is the ECM on our Stratus, how would I take it out, is it just a straight replacement (plug and play?) and where could I get one, most places online only go back to like 1998 models (they want you to send in your old one for repair). Thanks for any input, I could not find any videos or instructions on how to remove/replace the ECM, maybe because it is simple?
If you buy one online from a remanufacturer, they typically can put the VIN and such in it for you. These are NOT ones you want to go to a salvage yard and get. The BCM and PCM have to be the same type...type meaning anti-theft or NO anti-theft. If you get them mixed up, you can lock your car down and have to end up replacing both of them NEW. Not a fun thing...
