Stratus Not Starting, Timing?
I bought a 2000 Dodge Stratus 2.4l DOHC that had the timing slipped on it. I got it running, and it was running really well, until the check engine light came on and I found out it had low engine compression
I tore back into the timing system and it hasn't started since. All the timing pulleys are new, as is the belt and the spark plugs, spark wires, and the ignition coil. Could it still be that the timing is off? Or could something else be bad?
