Sedan - Fog Lights
Yes, it is. There's a variety of ways to do it.
You can either install an aftermarket kit from like an auto parts store/catalog, or you could order the OEM ones. The problem with either situation is you have to run wiring to turn them on. You would have to run a cable thru the firewall and you would have to mount a switch.
You could also consider contacting a dealership and enquire about having them installed. This would be more expensive by probably alot then doing it yourself, but at least it would be something you didnt have to worry about installing.
**** that, buy the lights on ebay and then if you want go to the stealership. if not buy em off ebay & go to a mobile audio place & have them do it since they deal with electrical stuff more often, just have them wire the light switch together with the fog lights for example, when you switch on the side (yellow) lights, the fog lights come on ( the lights before your main lights) you know what I mean
