Power window problems
Old Jun 26, 2018 | 09:47 PM
Dodgestratus03's Avatar
Dodgestratus03
Default Power window problems
I have a bit of an interesting problem with my power windows. I got a 2003 dodge stratus form my aunt and uncle and everything is fine but the passenger window motor. It would go down but not up so I first changed the motor. When that didn't work I changed the switch which also didnt work. So now I'm checking the wires. I first checked the up wire and it didnt show any volts, then down and going down it showed volts. Then just to see I put it on the up wire again while pushing the switch down, it shows volts so if its getting electricity to both wires while goung down Idk what else to do?
