Code P0171
Old Jul 8, 2018 | 06:16 PM
cbuck894's Avatar
cbuck894
Default Code P0171
2006 Dodge Stratus is running rough and dying when it is hot. Giving code P0171. We have changed the spark plugs, still no improvement. Any other ideas?
Old Jul 9, 2018 | 07:52 AM
Here's some ideas....start checking......
  • The MAF (Mass Air Flow) Sensor is dirty or faulty Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled.
  • There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor
  • Possible cracked vacuum or PCV line/connection
  • Faulty or stuck open PCV valve Failed or faulty oxygen sensor (bank 1, sensor 1)
  • Sticking/plugged or failed fuel injector
  • Low fuel pressure (possible plugged/dirty fuel filter!)
  • Exhaust leak between engine and first oxygen sensor
