No Heat HELP!
Old Dec 19, 2005 | 11:02 PM
daviszx3's Avatar
daviszx3
Default No Heat HELP!
my wife drives a 03 stratus sxt with the 2.4 and when the car heats up she has no heat when it sits at idle the blower fan is working its just blowing cold air but as soon as she starts going down the road it starts blowing hot air?? at first when it would sit the temp guage would start to go hot and loose heat but i replaced the thernostat and it doesnt do that anymore, the car isnt runing hot or anything she just looses heat i tryed flushing out the heater core but that didnt seem to help someone please help!! thanks erik
Old Dec 20, 2005 | 02:10 AM
tacoboy's Avatar
tacoboy
Default RE: No Heat HELP!
I was going to suggest the heater core as the culprit but as you have flushed the system, I guess not. Could the cooling system pressure suddenly increase when you start driving therefore enabling the coolant to run through the rest of the system? Once the car is idling and sitting for a while after driving, does the air cool off again or does it stay hot?
Old Dec 20, 2005 | 03:07 AM
kang25's Avatar
kang25
I had the same problem with my 02'r/t, the problem seems to be fairly common here. It's an air pocket in the radiator. I'm not sure if you can have your radiator re-cored or if you just need to refill it. I am opting for a new aluminum racing radiator myself, but I think you can just repair what is there. I have found a few people that seem to have the same problem though, and the just of it seems to be you can top off the coolant in the radiator and the resirvoir, maybe even using strait coolant instead of a mixture.
Old Dec 20, 2005 | 10:15 AM
brandoncrone's Avatar
brandoncrone
Sounds like you have a circulation problem for sure. Definitely make sure that the radiator is full, not just the overflow jug. Was the engine overheated before the tstat was put in?
Old Dec 20, 2005 | 02:18 PM
Stratusse2001's Avatar
Stratusse2001
In my 01 stratus with 2.7 it had and air pocket in radiator and once they fixed the heat works great. Hope this helps.
Old Dec 20, 2005 | 08:06 PM
daviszx3's Avatar
daviszx3
everytime you come to a stop and let it idle it blows cool air...but if you rev on it or start going down the road it gets hot again
ORIGINAL: tacoboy
Old Dec 20, 2005 | 08:10 PM
daviszx3's Avatar
daviszx3
no it never over heated the temp guage would start to rise but it never overheated, one time when the guage was reading hot i looked under the hood and the engine was barely hot i could hold my hand on the valve cover but it doesnt do that anymore the guage stays at a hair below half way
