1999 Dodge Stratus ES Throttle Cable Replacement
Old Mar 26, 2021 | 11:22 PM
RM-D150's Avatar
RM-D150
Default 1999 Dodge Stratus ES Throttle Cable Replacement
Hello does anybody have any videos or repair instructions on replacing the Throttle Cable from the gas pedal to the thtottle. I noticed that the cable was frayed. There was no room to try to put a cable splice. I thought that I could just put new cable into old cable housing seeing that what was left of old fraying cable was still moving and controlling throttle. I cut the few remaining steel threads on the cable and pulled the cable (easy enough) through the car by gas pedal But I tried to feed a cable back into the cable housing up under the hood where it comes out of housing and the cable would just not go into hole so Maybe there is something built into the cable housing that I am not aware of or I do not know what The other Problem is Finding the correct part a Throttle Cable assembly Please respond with any info thanks
