Can I just change the amplifier to an aftermarket one without the head unit?
SubscribeThread Starter
Is it possible to just change the amplifier and not the head unit? I have the Mitsubishi infinity system with 4 disc changer, but the amp doesn't work. Does anyone know what the ohms are for the speakers for this system?
The Forum Tyrant
coupe or sedan? you said mitsu, so i am guessing that you have a 2g coupe. if so, the stock amp is under the passenger seat. i think that 3 or 4 bolts hold it in place. the bigger issue with just replacing the stock amp is that there is a harness going into the stock amp, and a harness coming out. so you would need to either rewire things, or make a pigtail.
