Water damaged 2000 Stratus
Old Dec 30, 2021 | 03:09 PM
hooptieking's Avatar
hooptieking
Default Water damaged 2000 Stratus
I drove through high water and had to replace my engine. The water never was higher than the rocker panel, and now with the new (used) engine, it will run briefly, but not stay running. Could this be the ECM?
Old Dec 30, 2021 | 05:55 PM
ol' grouch's Avatar
ol' grouch
Could be. Did water get inside? There are computers and sensors all over the place, including under the carpet.
Old Dec 30, 2021 | 11:14 PM
hooptieking
no water got in the car at all
Old Dec 31, 2021 | 03:59 AM
ol' grouch's Avatar
ol' grouch
Why does it quit running? No spark or no fuel? Shoot a little starting fluid into the throttle body and see if it runs a bit then dies. If that's the case, your fuel pump or fuel pump relay may be going out. If that's the case, I'd swap the relay with a known good one. I got a truck once the previous owner had replaced the fuel pump and it still gave trouble. Swapping the fuel pump relay with the A/C relay cured it. Swapped them back and put a new relay in.
