Help with my main battery fuse!
Old Feb 6, 2025 | 04:36 PM
kerrianneta's Avatar
kerrianneta
Default Help with my main battery fuse!
I own a 2005 Dodge Stratus and recently started having trouble with it getting power/not starting. I was told by a mechanic that it was probably my main battery fuse. I went ahead and purchased a new one (Dorman Part # 926-012, I think). The only problem is I cannot figure out where to install it/where it goes/where it came from. I'm totally lost. Can anyone please guide me in the right direction in regards to figuring out where this main batter fuse is and how I go about putting the new one in. I really need my car back up and running. Thank you so much!
Old Feb 25, 2025 | 04:02 PM
thiefcrazy98's Avatar
thiefcrazy98
Originally Posted by kerrianneta
Hi! I also once looked for solutions to quickly increase subscribers and tried different services, including https://www.smm-world.com/buy-instagram-followers . And here's what I can say. At first glance, this seems like a good idea: cheap, fast and, it would seem, without much effort. However, there are several important points that are worth considering before deciding on such a purchase. Firstly, the subscribers you get for little money are usually not active users. Very often, these are bots or accounts with zero activity. That is, despite the increase in the number of subscribers, your audience can hardly be called alive. They will not like, will not comment on posts, and this greatly affects engagement - the main metric that Instagram pays attention to. Secondly, if you actively buy subscribers, especially cheap ones, this may arouse suspicion in Instagram algorithms. That is, if you have a large number of subscribers, but they are not engaged with your content, the likelihood that Instagram will begin to limit your posts in feeds or make your account less visible in general increases significantly. There is also a risk that you can be blocked for violating the social network's policy, since buying subscribers does not quite comply with their rules.
It's actually quite simple, you just need to find the 2 bolts that hold the battery charging generator and there you will immediately understand where and how to install it
