99 Stratus sensor identification/oil leak
Old Jan 21, 2006 | 09:19 PM
ousotsuki's Avatar
ousotsuki
Default 99 Stratus sensor identification/oil leak
99 Stratus 2.4
Last year I had my water pump and timing belt replaced. Shortly afterward I had a real minor oil leak ( few drops ). Now it leaks enough to locate where it might be coming from, but I'd like some help identifying the possible culprit. ( Driver side is to my left, passenger side is to my right ). Looking up from under the vehicle above the oil pan, left of the oil filter is a Black connector with three wires. Inches above and to the left is a Light Green connector with one wire. This unit sits under a metal heat shield. After cleaning the engine, I find oil around the back of the Green connector after running the car for a few minutes.
Ended up replacing the oil sending unit because of the single wire, which took care of the big oil leak.
I'd still like to know if there is a free website with parts illustrations for the Stratus.
