2.4 w/manual trans??
Old Jan 30, 2006 | 03:41 PM
token2's Avatar
token2
Default 2.4 w/manual trans??
Hello all. Will a manual trans from the 2.0 fit the 2.4 that originally had an auto? Any info?
Old Jan 31, 2006 | 10:18 AM
brandoncrone's Avatar
brandoncrone
Default RE: 2.4 w/manual trans??
The trans will bolt up, you may have to get a flywheel and clutch from a Euro minivan as they had manual transmissions available with the 2.4L. You would need a T350 or T850 transmission. Actually gets a flywheel and clutch setup from a SRT4 Neon, that has the manual attached to a 2.4 and the T850 (heavy duty transmission)
