how to get faster accelaration?
Old Mar 31, 2006 | 04:30 AM
friskyfisky's Avatar
friskyfisky
Default how to get faster accelaration?
i want to increase the power and especially the acceleration in my stratus sxt. how could i do this for a cheap price? also i'm kind of thinkin bout gettin some hood scoops for it and i wanna know if it would look good or not, tell me what u think, and if u got a pic. i would like to see it. thanx.
Old Apr 1, 2006 | 10:51 PM
disturbed driver's Avatar
disturbed driver
Default RE: how to get faster accelaration?
well i have a 2005 ......i dunno if it would be the same but i have found that by adjusting your pistons each by about ten degrees in any direction that you will sustain a higher acceleration rate ....also in this model dodge dont floor it or start it in low gear moving your foot down farther as you accellerate also using better gas is a good way ....i fin that premium gas is good but regular just doesnt cut it
Old Apr 2, 2006 | 12:58 PM
Z28Stratus's Avatar
Z28Stratus
If you want faster acceleration remove your heavy a$$ stereo..lol. Seriously though nothing cheap will make your car noticeably faster. If you have money to waste get some cams and have your heads ported. THis is your best bet.
Old Apr 29, 2006 | 02:27 PM
slick_stratus's Avatar
slick_stratus
bore out ur throtllebody with a dremmil tool with a corse sandpaper then with a fine grit ask me if u wanna know exzactly how to do it!!! WARNING: if u dont do it right then u are gonne buy urself a now throttlebody!!! or u can buy a jeep throttlebody and stick that on i heard that works. i wouldnt know though cuz i bored mine. there suppost to fit just like the stratus's. look it up
slick_stratus
hey im not gitting that check engine code but i am gitting many others....!!!! my map, maf,and tps, sensors are reading corralation at load.. and im gitting a high circut bank one sensor one error. i dont know what to do. i have replaced the map,map,and tps sensors and the check engin light never went off.. this is where it all started--------------------> i took off the cat converter and the car ran fine. ok. well about a week later i took off the throttlebody and bored it out but before i did that i undid my battery to reset the comp. i bored it out then hooked it back up. then the problems began. thats when i replaced all of that ****.... then i went and got 2 new o2 sensors check engin light still on! i went and got a dio done again i was gitting low circut bank 2 sensor 2 i know this wont make sence but hear me out. high circut bank2 sensor 2 ...... yeah.. so i bought a o2 simulator to simulate the cat converter to try to solve the problem and i got another dio done. i must of got like 25 dio's done by now... and i was reading low circut bank2 circut 2 so i fixed that and again went and got another dio done and now im gitting map, maf,and tps, sensors are reading corralation at load.. and im gitting a high circut bank one sensor one error and the car's rpm's wont let me go past 3500.. it bounces like the governor is stoping it when im swithching it from 1st to 2nd to 3rd and so on and when i stop or stay stedy on gas it bounces at 1000 rpms. and when on stoped it will try to cut out almost stalling then catch its self BOY IS THIS CAR PISSING ME OFF. PLEASE HELP CUZ PEOPLE IVE WENT TO DONT KNOW **** ABOUT MODDING CARS AND TELL ME WHAT I KNOW IT IS NOT....................SORRY IF THIS IS A REPEAT FOURM U HAVE SEEN ALOT OF BUT I NEED MAJOR HELP BAD IM RUNNING LOW ON IDEALS!!!1
