engine noise
Old Apr 16, 2006 | 06:39 PM
JokernickRT's Avatar
JokernickRT
Default engine noise
hey, I got a 2001 Stratus R/T.......... I just changed my spark plugs in my car, and you probably know what an ordeal that is, anyways after taking apart the intake, I changed the plugs, then reassembled it, now, when it starts up, it runs and sounds great, but when I put it in gear, a loud noise happens, almost like a crakeling noise, any of you guys know what this might be????
Old Apr 29, 2006 | 02:16 PM
slick_stratus's Avatar
slick_stratus
Default RE: engine noise
hey im not gitting that check engine code but i am gitting many others....!!!! my map, maf,and tps, sensors are reading corralation at load.. and im gitting a high circut bank one sensor one error. i dont know what to do. i have replaced the map,map,and tps sensors and the check engin light never went off.. this is where it all started--------------------> i took off the cat converter and the car ran fine. ok. well about a week later i took off the throttlebody and bored it out but before i did that i undid my battery to reset the comp. i bored it out then hooked it back up. then the problems began. thats when i replaced all of that ****.... then i went and got 2 new o2 sensors check engin light still on! i went and got a dio done again i was gitting low circut bank 2 sensor 2 i know this wont make sence but hear me out. high circut bank2 sensor 2 ...... yeah.. so i bought a o2 simulator to simulate the cat converter to try to solve the problem and i got another dio done. i must of got like 25 dio's done by now... and i was reading low circut bank2 circut 2 so i fixed that and again went and got another dio done and now im gitting map, maf,and tps, sensors are reading corralation at load.. and im gitting a high circut bank one sensor one error and the car's rpm's wont let me go past 3500.. it bounces like the governor is stoping it when im swithching it from 1st to 2nd to 3rd and so on and when i stop or stay stedy on gas it bounces at 1000 rpms. and when on stoped it will try to cut out almost stalling then catch its self BOY IS THIS CAR PISSING ME OFF. PLEASE HELP CUZ PEOPLE IVE WENT TO DONT KNOW **** ABOUT MODDING CARS AND TELL ME WHAT I KNOW IT IS NOT....................SORRY IF THIS IS A REPEAT FOURM U HAVE SEEN ALOT OF BUT I NEED MAJOR HELP BAD IM RUNNING LOW ON IDEALS!!!1
