TURBO TALK
So I Found A Turbo For a 2000 Eclipse GT, which is the same motor as an 01 R/T. It Will Work On It Correct?
And my second question is what types and where can I find an innercooler for my car? if andyone knows anything please let me know,
it would help a **** load!
you can put any intercooler on your car...they are basically universal. it depends more on the turbo kit, as you want to have an intercooler that has inlets and outlets the same size as your turbo piping. also, it depends on how the piping is routed. If the piping comes from the turbo, to the front mount intercooler (FMIC) on the same side as the throttle body, youll need an FMIC with the inlet and outlet on the same side. You could go with an FMIC that has the in and out on opposite sides, but it will be a ton more work, and a ton more piping, and the more piping you have, the less actual boost you have, at the throttle body.
who makes this kit that youre looking at?
hmm..its not a kit..its just two used turbos...just so you know, used turbos can easily be bad..especially for that price.
also, that person could have put anything where it says "great for custom eclipse GT". the turbos are the easiest thing to find for the "kit"...the manifolds are the most difficult.
