95 Stratus v6 2.5L SOHC, Oil Pressure Sensor Location, Rough When Warm?
Picked up an 95' stratus with about 90k miles on it for $1000 but had to do a bit of work. Needed an out of province inspection and I've fixed all the bits except for a leaky tranny pan gasket and a leaky oil pressure sensor that the inspection found.
Where the heck is the oil pressure sensor on this engine? I have a haynes repair guide and it makes mention of it under troubleshooting but has no reference to it's location or how to service it. Any description should be fine, as long as I can find it, how to get to it, and if it's just a gasket or a specific ring, or just some sealant will do the job...
Also, the car drives great when cool, but after the engine warms up for 10 or so minutes the thi ng idles rough, stumbles on acceleration, and surges a bit when cruising above 30mph. I checked codes thru the check engine light and it spits back codes 32 and 33.
Any word on where to start...
