How do I change the alternator in a 98 stratus?
I have a 97 - if similar, it's remove the plastic guard above the belt then remove the two bolts anchoring the alternator to the bracket. There is a pivot bolt and an tension ajustment bolt. Then just unplug it and install the new one. Make sure the belt hasn't skipped off of a row on the new alternator or other pulleys. Hope this helps.
taco
taco
