? for SE Coupe owners
Old Jul 19, 2006 | 11:01 PM
SilverStratus06's Avatar
SilverStratus06
Default ? for SE Coupe owners
I have no idea how to get the rear rotors off and i wanna install my rear drilled slotted rotors because the front ones look good and the back looks like **** can any one give me a step by step how too after the caliper is removed
Old Jul 20, 2006 | 01:29 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: ? for SE Coupe owners
I take it they are nice and stuck on the car? Once you get the caliper off....there are two different size bolts. You should have 2 that are long and 2 that are small.
On the face of the rotor, should be two smaller holes. These may have a piece of rubber filling them in but you will notice them rather easily.
[IMG]local://upfiles/19085/E3DCCAC315564FAC8FB063FA93B7F63F.jpg[/IMG]
Once you've located these, take the smaller of the two bolts from the caliper, and insert these into the holes. You will find that these fit the hole and you can use these to break the rotor free. Just slowly turn them each...give each one like 2-3 turns and then go back to the other one....
It worked for my rotors no problem....
Old Jul 20, 2006 | 05:34 AM
SilverStratus06
Thanks we noticed them and thought maybe they had some sort of spring release
