considering a 2003 stratus rt..??'s
ORIGINAL: dizzygrinch
hello, I am looking to buy a used 2003 stratus rt. Are there certain things I should look for? also, i have heard that the 2.7's are bad motors, should I be leary?
The 2.7L's have a bad history with sludge....but I'm not sure if that applied to the Stratus model or not. You'd be better served to ask BadStratRT or Thump186.
As for things to look for, check for the last major maintenance, as the timing belt and transmission are two things you want to keep a good eye on. If the cars around 50k....look over the struts as they're close to being do for replacement....also keep an eye on the motor mounts....as they're crappy rubber and will most likely have worn down or worn out...
