HELP! Oil by spark plugs!
Old Aug 15, 2006 | 11:04 AM
andym1999's Avatar
andym1999
Default HELP! Oil by spark plugs!
Hi... I'm kinda new to the Stratus scene. I recently changed the plugs on my 2000 2.4L that I had just bought. When I pulled out the first plug it was covered in oil down by the hex portion of the plug. 3 of the other 4 were the same way. Anyone have any thoughts as to where the oil is coming from?
Thanks,
Andy
Old Aug 15, 2006 | 12:35 PM
dodgedlr's Avatar
dodgedlr
Default RE: HELP! Oil by spark plugs!
Does this engine have the spark plug in the center of the valve cover? I don't recall right off hand if it does or not.
But, if it does, you need to replace the O'rings in the valve cover around the spark plug holes.
Old Aug 19, 2006 | 12:23 AM
andym1999's Avatar
andym1999
Yes the plugs are in the middle of the cover. Will I need to change the gasket as well???
Old Aug 19, 2006 | 01:24 PM
01indigoR/T's Avatar
01indigoR/T
well it probably wont hury to change the other gasket as well. it comes as one kit; vlave cover gasket and the o rings around the sparkplugs.
Old Aug 22, 2006 | 05:04 AM
strat101's Avatar
strat101
thats funny cause i just replaced my gasket and it does come in one kit and it took me only about a 1hr and half to do. Dont forget you have to remove the coil pack in order to get the bolt under it. Have fun!
