Engine hesitates when started
Old Sep 14, 2006 | 01:51 PM
krs_si's Avatar
krs_si
Junior Member
Default Engine hesitates when started
When I crank my car the engine acts like it wants to shut off and then its normal again. It only happens for a few seconds. Anyone experienced this or have any clues as to what it could be?
2003 2.4l 4cly Stratus SE
Old Sep 14, 2006 | 11:03 PM
SilverStratus06's Avatar
SilverStratus06
Default RE: Engine hesitates when started
same problem with my 01 v6 coupe
Old Sep 15, 2006 | 03:33 AM
Tommygunz's Avatar
Tommygunz
I am having a similar issue with our 05 R/T. now that it is cooling off considerably in Montana, we are noticing that once started in th morning chill, the mototr stumbles wuite a bit until it warms up a bit. Where could this issue be coming from and what can I do to remedy this?
Old Sep 15, 2006 | 04:23 PM
tomthedog's Avatar
tomthedog
if you have not already, make sure the spark plugs are in good shape. you can try brushing them off with a wire brush (BBQ grill brush works) to get the soot off. try putting di-electric (spelling?) on the plugs/plug wires (both ends) for better conduction. check the connections to/from coil pack. checl the air filter and general tune-up stuff. try leaving the key to "on" just before start to let the fuel pump build up press for a few seconds before starting. good luck.
