2.5L V6 Engine-Mounted Power Steering Bracket (casting) Removal
Old Sep 16, 2006 | 12:55 PM
allenl44's Avatar
allenl44
Default 2.5L V6 Engine-Mounted Power Steering Bracket (casting) Removal
Am in process of replacing Timing Belt on 1999, 2.5L V6 engine (Chrysler Cirrus, but same as Dodge Stratus). Power steering pump is mounted on a small bracket. The PS pump & bracket assembly then mounts to an engine-mounted bracket (casting) which MUST be removed in order to get the right (rear) timing belt cover off. Have removed PS pump & small bracket from casting. Have removed two bolts from lower end of casting, but cannot find another fastener (spent 4 hours looking). Official Chrysler shop manual gives minute details on other R&R, but nothing on the engine-mounted casting (number & location of bolts).
Thank,
allenl44
